Re: Ft Lauderdale/Dania Cutoff canal
I did it earlier this year (and last year and the year before). I love that loop. I've even done it at night.<br /><br />If you're a small outboard, the only tricky place is just south of the 595 bridge. There's a stretch of a hundred yards or so with white pipes to keep you in deep water, but it's not always clear which side of the pipe to be on. We idle thru that section, keeping a sharp eye on the sounder, otherwise just keep her in the middle. Even small outboards can be stopped at the railroad bridges - it appears they keep them open unless a train is coming so just wait if they're closed.<br /><br />The only other concern is finding the connector between the Dania Cutoff and the New River. From the DCoC side it looks like you're turning off into the woods (and you are) before you get to the 441 bridge. From the New River side, it's the second left beyond Secret Woods Park (a wooded preserve on the south bank). At that left, you'll thread your way through a marina/yard, then under 2 sets if bridges (84 & 595), then into that stretch w/ the white pipes. <br /><br />If you go to the link below, and click on Maiden Voyage, there's a paragraph or two about the 'loop'.<br /><br />Drop me an 'e' if there's anything else you need.
