Froze clamp
bouttime007
The transom clamp/screw on my 1965 3 horse WILL NOT budge.
Tried working it back and forth with vice grips and some lubrication, but no dice. Im getting the feeling something is going to snap if I put more mustard to it...
Any ideas or tricks?
itsaboattime
Re: Froze clamp
PB blaster and let it soak for a couple days.
Is it mounted on a boat? If not maybe some heat...not alot!!!
bouttime007
Re: Froze clamp
Its not on a boat. YET.
I was going to run it in a barrell but the damn clamp wont move. I'll soak her down and return after a half dozen coffees. LOL
Thanks
(cool name by the way)
Daviet
Re: Froze clamp
I bet heat is the only way you are going break it loose.
Will Bark
Re: Froze clamp
If PB Blaster doesn't work try a 50/50 mix of acetone and auto transmission fluid may work better for you. Good luck
tx1961whaler
Re: Froze clamp
Wish I could offer some advice. I have a set of 3 hp transom brackets hanging on the garage wall that are frozen that I could never get to budge. Got new (well, old ones that weren't frozen) ones on ebay.
itsaboattime
Re: Froze clamp
too much heat will prolly pop the casting...I think they were aluminum back then. Too much torque will strip the threads. Be very careful!!!
bouttime007
Re: Froze clamp
Thanks guys. Yeah, all aluminum.
I dont know how much heat I dare apply, but it may come down to the flame in the end.
