from 82 115 rude to 96 150 OP rude
crazy charlie
Hi guys,I am looking at a 96 150 ocean pro evinrude to replace my tired 82 115 evinrude on my 17ft Mako.Will it adapt to the existing controls??????Charlie
JB
Re: from 82 115 rude to 96 150 OP rude
What's that Mako rated for, Charlie? :confused: <br /><br />I suspect even the 115 is overpower.<br /><br />If my suspicion is right it would be a very bad idea. :eek:
D
DJ
Guest
I believe a Mako 17 is rated for 135. The 150 is overkill.
DHPMARINE
Obviously you'e seen the above replies,and these guys are looking out for you.<br />There is a harness available.<br />DHP
crazy charlie
I already assumed the 150 was a little big but i dont have many choices.I have been looking for a used motor since October and the only ones that I have come up with that are in my price range are either too big or too small and too old.This is the first clean,newer motor that I can afford.My second choice is an 82 140 johnson but I really dont want to replace a salty old motor with another less salty old motor.I think the 150 weighs about another 60 lbs.I understand the point.What would the harness cost???Charlie
