Lake Sonoma: Nestled in the beautiful coastal foothills of Sonoma County, California, Lake Sonoma is surrounded by world famous vineyards and land that is rich in history. Created by the construction of Warm Springs Dam in 1983, the lake provides for flood control, irrigation and recreation. When full, the lake has a surface area of more than 2,700 acres and 50 miles of shoreline [Lake Sonoma. www.nwk.usace.army.mil, 02/03/2008]
08/25/2012 -
Who - Jlawsen, NGT
Boat - 16' JetCraft Falcon, "Pole Dancer"
On the water at 6:30am, heavy fog, visibility 20-30'
Air Temp 49-70F
Wind 6mph E-SE
Surface temp 71.6 F
Visibility to the bottom - 12' at the dock.
Oxygen at the surface - Excelent - Good aeration through fingers when run through the water.
Average depth: 200'
Best color for fishing should have been something dark but there were several bait balls in the water. We decided to run silver and orange 1-0 Apex Kokanee Killers with double hooks tipped with a full mini night crawler.
The silver was run off the downrigger at 60' and the orange was run off 4 colors of 18lb lead core with a 16' FC leader.
Trolling speed was 1.8mph maintained by cruise control.
The first fish, a 16" Natural Steelhead was caught on the orange Apex/lead core on the Dry Creek arm nearly center and up about 1 mi from the Dam. The size of the fish indicated that the smaller fish pod had moved further down towards the dam and the larger fish were likely up further near the no-ski bouys.
The hunch was right, the next fish was a 24" 3lb Steelhead caught just below the bouys on the down rigger at 60'. The thermocline was deep and it was likely that the water clarity was reduced at that level due to the annual algae die off. That's why the silver Apex was working. We switched the lead core to silver and picked up a the third fish a 18" 2lb. I picked up a small mouth bass that didn't trip the release and got drug for 15min and one more 18-20" Steelie near the same location as the first. That one shook the hook at the boat.
The lake is shapping up for fall and with two years of excellent water levels the fishery is begining to restore itself. The daily limit on Steelhead is 2 per licensed fisherman. The pole limit is one unless you have a second rod stamp. You do not need a Steelhead card to catch non-anadromous Steelhead. Persons under 16 do not need a second rod stamp. There are no rainbow trout in this lake, do not make the mistake of keeping 5 thinking they are rainbows, the fine is heavy.
Anticipated Next Report - 9/8/12
08/25/2012 -
Who - Jlawsen, NGT
Air Temp 49-70F
Wind 6mph E-SE
Surface temp 71.6 F
Average depth: 200'
