agallant80
- Oct 25, 2010
- 2,328
The pump for my fresh water tank died. I bought the boat new in Feb so it was not age that killed the pump. It is a pressure pump so when you turn on the fosset it senses the loss in pressure, turns the pump on, then when you turn the fosset off it will build up to 20PSI and turn the pump off. Is leaving the system pressurised killing the pump or was it just a fluke where I got a bad pump. I can't see anything in the manual that says to not leave the pump on all of the time (it does not run all of the time just keeps 20PSI in the lines). When I took the old pump apart the diafram had a bad seal, water got in to the electric motor and rusted everything up.
