Re: Fozen shaft cable stuck inside tilt tube.
Assuming you have taken the linkage loose and the Nut off the tube that retains it(The Big One).?? If so, you may need to use some penetrating oil and some persuasion to break it loose. Shoot some oil where ever you can get to and let it sit overnight. If you can put grease into the fittings, that would help also. Then try again in the morning. Try tapping it out with a hammer and see if it moves. If this fails, apply a little heat with a propane torch to the tube, back and forth movement, and try to pull or knock it out. Should come out!
