fourstroke outboard weight
jamiepom
I have a question about outboard weight. I have a 1991 smokercraft 16vfl 16.42' 69" beam 350lbs. 40hpmax this is a bench seat boat
I have the opportunity to buy a 2009 mercury 25hp fourstroke motor weighs 187lbs.
my question is will this engine be to heavy? If this boat was rated in 1991 at 40hp max what is the weight of a 40hp 2stroke then to a new fourstroke?
i'm interested in the 25 fourstroke because its a great price
thanks for any info
Bob_VT
Re: fourstroke outboard weight
The older 40 HP are right around the same weight...... You will have no worries.
Welcome to iboats!
steelespike
While your well within the weight of a 40 hp in 91 keep in mind your adding the weight of a 91 40
with a 25. In 91 a 25 could be a light as 110 lbs.
Typically a small 4 stroke will require careful prop selection and weight placement.to achieve
decent hole shot.I know your probably getting a real deal but give a direct injection 2 stroke
some thought.The 25 and 30 hp Evinrude Etec is 147 lbs no service for 3 years or 300 hours.
fewer less complicated service intervals better holeshot and about 30 mph on a boat like yours.
jamiepom
thanks for the feedback. I will look into the etec.
jamiepom
the 09 mercury 25hp is priced at $2495 it has apox. 20hrs
steelespike
09 with 20 hours You might wonder why it was turned in.
Performance issues?weight?I wonder what a new 4 stroke sells for?
jamiepom
the dealer selling it sold it new. Guy bout it for an old boat used a few times then bought a new boat package from the dealer. He junked the boat and is selling the motor
I am going to look at an etec 25hp today $3500
steelespike
Just found a test Alumacraft V16 16'8" 280lbs,Etec 25 tiller, 2 men,6gal fuel,gear and battery.
31.6 mph at 6000. 10.3 X 12" prop
