Four Winns info
Sting
My son just bought a 1988 Four Winns, 241 Liberator, Cuddy cabin. The cabin floor has a lot of water under it, Four Winns , for what ever reason, didn't install any sort of drain, or pump in the cabin area. Does anyone have info on this problem on Four Winns boats, the step down can't be removed, like on a Searay to access below the cabin floor. Thanks for any help folks,
fone_man
Re: Four Winns info
this was probably a Texas/FourWinns boat...<br /><br />I have 18 ft Four Winns w/140 Merc IO...<br /><br />I am trying to figure out what you are saying... water is standing in hull of boat & not draining to transom area for drainage??? Right???<br /><br />If this is so... put in drain line... get flexible hose & plastic fittings, run onder deck to area you want it to drain too!!!<br /><br />Boat is thirteen years old & I doubt they ever changed it... configure it the way you want it to drain...<br /><br />let me know...<br /><br />
<br /><br />------------------<br />"Keep It Between The Bouys" & "Good Luck"!!!<br /><br />fone_man
