Found the # on prop but can't find it online
Bustedknuckle84
I pulled this number off the prop 48 773499A4c<-this is backwards 17P . Im wanting to to buy an stainless steel prop. I am satisfied with the rpm @ WOT now so dont want to change pitch.
i am assuming 17P is a 17 pitch???? anyone???:confused:
boat setup is below
Re: Found the # on prop but can't find it online
Ayuh,... That's exactly Right....
Fun Times
Also if that is a "C" at the end of your part number, Then would tell you the prop is Cupped.
Are you sure the part number is correct? I can not find anything out about it as well.
Bustedknuckle84
yeah i sanded the paint off to get to the whole number. I can't even find it on the diagrams on oem sites.
