cougar1985
- Oct 7, 2005
- 1,023
for those of you ,s that have read my previous posts on my 1963 75 elecct shift starflite you know that on its madien test run she failed about a 1000 yards from shore.basically shuddered and stopped running and would not start again .well she has been replaced with a great running 1966 electamatic 80 hp johnson so i have decided to tear apart the 63 for parts.heres what i found when i took the lower unit off.just below the splined end it looks like it was machined clean off!the shaft that is .i will assume the rest is in the bottom of the motor.what would cause this to happen ?a failed bearing?
