Hi folks,the problem i am having is fouling plugs on my 40 hp Johnson(TJ40ELESR).This motor is on a 20 ft. pontoon at a no wake lake so low rpm's may be the biggest problem,but there are a lot of other pontoons on the same lake with as big or bigger motors than mine that don't really seem to have a problem.The plugs that i have tried are champion QL77JC4 and NGK BR8HS.I have kitted both carbs, and have it running real good,but after about 8 hrs of run time it gets hard to start hot or cold,so i switch out the plugs and it purrs like a kitten again.Any suggestions on plug numbers ,gap or oil mix(50_1) that might help the situation? thanks Tim
