I have a 1995 Bravo Three stern drive with a 7.4L engine<br /><br />Ive been dealing with a forward shifting problem for the past couple years, and the problem gets more frequent with time. I noticed when the boat runs out of the water (on lift) I can shift without any problems (works 100%).<br /><br /><br />Ive had the stern drive removed once for normal cleaning and lube, but the mechanic wasnt able to find anything wrong with the shifting. I had the mechanic replace the lower shifter cable anyway. The problem went away for a couple weeks, then reappeared. I then had the unit removed again, but still unable to find a problem, without replacing anything I put everything back together, it worked for a couple weeks then problem came back. Last week I took the boat out for a test drive hoping that the problem may have magically disappeared, but not the case, in the water it shifts into forward about 50% of the time. If I wiggle the control shifter I can sometime get it into gear. If I go beyond the shift position on the control the RPMs go up and the forward gear bangs into position. I put the boat back on the lift and tested the shifter again, it shifted 100% without any problem. I cant understand why it works okay out of the water, but not in.
