Hi,
When i put the boat in gear ( without it running ) it seems very stiff , i have never ran a boat on the water and was just wondering if this is normal , i know its not the gearbox as i had the lower end off and i could move the rod ok , but when i connect it all back up its stiff ,
I have greased the nipples and worked it back and forth it got a bit better but its not really easy but it does go in forward and reverse with a little force .
is this normal ?
Thanks
is this normal ?
Thanks
