Forum avatar
dmtalon
Don't see a place to ask questions about forum issues, so here I am :)
I have added an avatar to my profile and it is quite visible to me in my profile, however I have posted a couple posts since adding it and do not see it on those posts. Is there a certain post count or some other reason why its not showing?
Thanks,
toneeees
Administrator
Re: Forum avatar
Thanks,
Hey dmtalon,
There is an Avatar and Profile picture. You seemed to have uploaded your picture to the "Profile Picture" section, and not the avatar. You can simply upload the same pic to the avatar section of your profile and it should work.
Click Settings at the top.
- Find "Edit Avatar"
- Select "
Use Custom Avatar"
- Then select how you'd like to access the photo ( Either uploading it or using existing link)
Existing URL would be -
http://forums.iboats.com/customprofilepics/profilepic356512_1.gif
Let me know if you have any questions.
dmtalon
Re: Forum avatar
well what do you know :facepalm: Thanks for pointing me in the right direction!
dmtalon
Re: Forum avatar
No problem! Let me know if there's anything else.
Thank you Toneeees... I'm not generally too needy so hopefully I'll be good now! I'm not used to a forum having both a profile and avatar picture and apparently it confused me :)
