ford 302,190 hp cooling issues
southkogs
Depending on what year drive you have, everything exiting might be happening under water. What type of drive do you have?
Welcome aboard.
SpitAndDirt
Take a look at my video. It explains how the cooling system works. Keep in mind that the stock lift pump located in the rear of the Cobra drive doesn't output nearly as much water as the sump pump used in the video.
