Re: Ford 2.3
Thanks Don. Yes, the compression test was done last year and it was within nominal range. NO vacuum tests were done. Timing adjustments were made as part of last year's tune up and replacement of ignition cables, rotor... They've checked the carburator as well since I wanted to replace it. They said it was good, they just cleaned it. The problem with this boat is, it is alwasys behaving well at the beginning of the season. We are in Ontario, average air temp is about 25C July-August. But always near the end of the season (towards end of August), the engine starts developing stalling problems. It would start just fine, idle at nominal rpm but when you load it, it would just die. I am wondering if it has anything to do with air density change as the air gets colder in August/September? Would a carburator adjustment solve this problem? I am not sure how to adjust it but I guess I can get a shop manual if needed.<br /><br />Any suggestions?<br /><br />N. Aydemir
