bushdoctor
- Jun 26, 2004
- 3
I have a 1992 50 hp Force with CD ignition which has very low hours due to life on a boatlift and no use.After rebuilding carb.,fuel pump & waterpump the engine ran great for several trips.When approaching the dock and putting it into neutral,the engine stalled and would not restart.Since then engine will start only with the fast idle lever all of the way up and will proceed to idle OK,when it is shut off, it will not restart until you place your hand in front of the carb and "choke" the engine.I want to run a compression test and vacuum test, how do I perform the vacuum test?
