Re: Force trim????
I have to agree with revertmastec. I thought I had a tilt/trim function on my Chrysler 70HP but I came to learn that it was a tilt only. There is a cylinder for each function and on the Chrysler's anyways, there's 4 hydraulic lines coming from the main pump if you have the trim option.<br /><br />As far as leaking down when out of the water, it would be an air pocket or a leak somewhere. Also, does the motor tilt up when you're in reverse?<br /><br />Also ensure that you're using the correct oil for your system. I cannot be sure what type of oil is recommended for Force motors. I can only imagine there's a plug on the side of your resevoir.<br /><br />I would have put hydraulic oil in mine also if I didn't read the manual. Mine takes a grade 30 Non-Detergent motor oil but like I said, it's a Chrysler.<br /><br />Good luck
