I have a 85hp Force model no.856x5l serial no.<br />2884 1985 model. Started the engine and it started fine, but then I shut it off and went to restart it but never started again. It had been cutting out when WOT, but this time it didn't even attempt to start back. I checked the plugs and they didn't have any fire. I noticed the blue and yellow wires coming from stator. One of the blue wires had been cut where the plug connects to the cdm and spliced into the other blue wire. It has two sets of wires: blue and yellow to one cdm and the other set to the other cdm. So in other words one cdm has two blues and one yellow and the other has one yellow but no blue. Is this wired right?? It's a 6 wire stator. Is it fried? ohms read 1.4 when I checked resistance. It's supposed to be 0.5-1.0 <br />It's a prestolite system so it says on the flywheel
Wiring diagram would be appreciated.
