Force power trim/tilt fluid
RTW2112
Hi, anyone know what fluid goes in a 1983 Force 85 hp power tilt/trim motor? I have 2 different manuals, 1 says to use ATF and the other says to use straight 30 weight oil. Any help would be appreciated.<br /><br /> Thanks, Bob
clanton
Re: Force power trim/tilt fluid
Different also says 20 wt. I would use what was in the system, if it was working. 2nd choice Dextron ATF.
