Force number 2 cylinder bad
TahoeDave
I've had my mechanic check my 1992 90HP Force out. numebr 2 showed bad compression. decarbed and did a leakdown compression test<br /><br />number 1 is 13%<br />number 2 is 33%<br />number 3 is 15%<br /><br />He says probably scoring on the walls. I've called around to some places and they think it will cost around 1800-2000 dollars to fix.<br /><br />What would you all suggest I do? how much do you think I can get if I part it out or sell it as is?
imported_bjs
Re: Force number 2 cylinder bad
i would pull the head off myself had mine off its very easy if you have a manual? iwould buy 1 if you dont already have 1.looks like #3 is the problem.
TahoeDave
racer,<br /><br />Thanks.<br /><br />he said number 2 was the issue. leakdown % being over 20%. something about the % of air passing.<br /><br />Maybe I don't understand the leakdown compression test numbers?
roscoe
Pull the head and examine to determine extent of damage.<br />Parting it out on ebay should bring $600-$900.<br />Selling it whole, probably only $500.<br />WHY? Because who wants to buy a bad motor and pay an enormous shipping fee, when they only need a lower unit, ignition system, or carb.
