force LDRIVE winterizing?
pcmoto
what do you do to winterize one of these motors & outdrives Im used to mercs so im not sure what to do. Please help!!!Ive got a clymer manual & it says nothing about it!
D
DJ
Guest
Re: force LDRIVE winterizing?
pcmoto, <br /><br />I am no L-drive expert by any means.<br /><br />However, that engine should be treated for what it is, an outboard in I/O clothing.<br /><br />Since it sits upright, I'm sure the water will drain out automatically. With that behind you, just fog it like you would an outboard. Don't forget to treat the fuel with something like SeaFoam or StaBil. Make sure you run treated fuel through the carbs also.
roscoe
And change the drive unit oil, disconnect/remove the battery, grease the propshaft, clean her up.
