Force 90hp colling system
kpgpdp
Hope somebody can help. My Force 90hp was overheating so I replaced the impeller. There is a good flow of water at low revs but this becomes less as I increase revs untill it stops and the overheat alarm sounds. The old impeller was completely destroyed and I am wondering if some of it may have found its way into the cooling system. Any suggestions on how to solve this would be greatly appreciated as this is my first boat so I'm a bit lost.<br /><br />Cheers<br /><br />Dave
roscoe
Re: Force 90hp colling system
Remove the lower unit.<br />Then remove the thermostat housing and thermostat.<br />Use a garden hose to force water into the thermostat opening in an effort to back flush the motor.
