QuadManiac
- Jul 2, 2007
- 391
As I was stowing my '91 Force 90 for transport the other day, i noticed that the entire lower assembly would rock back and forth without the engine case moving. Upon removing the power head cover, i now see that the entire assembly, lower and powerhead, is able to rock back and forth about 2" (at the prop). There appears to be 2 puck like motor mounts below and on either side of the power head. There is also some kind of mount at the top rear, that looks like it should attach to the powerhead, but does not. This is a metal angle bracket with 4 bolts on the horizontal surface into the outer case. The vertical portion of the angle bracket points down, and it looks like it may have once had a rubber puck attached to it which then surrounded a boss on the power head. (I say this because there are some ~2" diameter circular marks on the vertical flat towards the powerhead) There is nothing there now.
Is there supposed to be some physical connection between the outer case and the power head at the top rear? Is this rocking motion normal?
My manual does not have enough pictures to show me what it should look like, and since it's for every motor made (practically) the descriptions are pretty generic.
Thanks, in advance, for your help.
