Force 90 electric choke
Cholmes
a guy brings me one of these to get running for him. It is a 90 hp US Marine Force. I notice the choke isnt closing so i put power to it. Traced to the ignition and there doesnt seem to be power at the terminal where the connection is. Is there supposed to be power to the choke when the key is on or only when key is in crank position? I am not familiar with these at all.
Jiggz
Most force ignition systems use the "Push in" style ignition switch to activate the choke. Hence, you push in first and while holding down, turn to "On" and then to "Start" to crank it over. Make sure you follow standard starting procedures.
1. Press primer bulb until firm
2. Place control lever (remote throttle) in high idle position
3. Push in ignition switch to engage choke
4. Turn to On and then Start, for about 5~8 seconds.
5. If engine starts let go of the choke. Otherwise, if engine only "coughs" let go and place switch back to off.
6. Re-start without engaging "choke" to see if engine starts.
The carbs can easily flood with the choke being activated. Usually, choke only once or twice at the most.
Make sure cooling water is always connected while running motor even for testing only.
As soon as motor starts, warm it up for about 20~30 secs and you can put the idle back to normal.
jerryjerry05
Turn the key to the on position.
Then push it in, it should activate the choke.
If not? test light at the green wire on the choke solenoid.
It should light up when it's energized.
Sometime they get corroded and need a shot of WD on the slide.
