Haven't looked at it yet but a friend asked me to look at his outboard motor. The problem seems to be that it doesn't like to go in the water. Engine will run fine with earmuffs and the trusty hose. But at soon as you back it in the water it will not start. Seen one other post about this but there was no follow up. So when I check this motor out were should I look past the basics? Thanks in advance.
