Force 9.9 spark plug
tedede
I have a 1987 Force 9.9 and it's running pretty well with the occasional cough. I figured I'd start off with new plugs.
This site:
http://www.go2marine.com/docs/mfr/champion/champion-t3.shtml
Calls for L87YC, but I found an RL82C in the outboard.
From what I read online:
- The L is the size, same on both
- C is a copper core, same on both
- Y is "Standard Projected Nose Cone"
- 82 vs 87 is the heat range.
- R at the beginning, racing???
Aside from "this is the closest they could find", is there any reason why one would sunstitute a slightly cooler, non-racing plug without a projected nose cone in the outboard?
tedede
Re: Force 9.9 spark plug
sorry, meant to say racing, not non-racing. tried to edit the post but it wouldn't save.
jerryjerry05
RL-82 or SPARK PLUG (NGK # B6HS) Try these.
Need the model# and serial#
You'd be surprised how many different plugs were suggested for this motor.I've found about 4-6 variations
4-6 different #s depending on serial# The block and heads a bunch of changes.
R means resistor plug.
tedede
Thanks for the reply.
Here's some additional info if that would help.
Model: 92F7A
SN: 2544
jerryjerry05
Sorry I didn't read the first post right!!
The plug in it was?? Just replace it.
The cough is probably the carb.
Start motor.
Air screw in till it coughs,bucks kick or stalls.
Then out 1/2 turn.
This should take care of it.
G
Guest
Guest
are these plugs also good for the 15hp one also?
