I have just put a new and tested starter on my 88 85hp force outboard. First time i turned the key with new starter everything worked fine. Next 20 times i tried starting the motor the bend-ix wouldnt engage. So i removed the starter and tested it again and worked fine. After putting starter back on and putting wires back on the outboard turned over fine, 4 or 5 times it turned over fine. So I got my fuel tank ready and tried starting the motor. once i tried to start it again I havnt been able to get starter to turn flywheel ever since. Is my reset bad cause i dnt see anything to push on the reset,
