Hello guys,
Yesterday I took my RIB for a ride. After 1/2 hour it started to stop working. On the beginning it was just for 2 - 3 sec (behave like a turn off for this time), then it appeared often and often and then lose power (about 3 - 4 min and then died). I was 500m away from the beach....
When removed it from the water I checked spark plugs and there was no spark on any of them.
After a while main fuse started to blow. Every time I turn it on it blew again. Right now, it happens every 5 sec...
Do you know what it might be?
Can it be voltage regulator? Maybe it's worth to mention that my tachometer has not worked at all even I bought new one.
Thank you for your help....
