I recently picked up a 1988 17' Bayliner Capri with an 85 hp Force outboard. At first, it was either it would idle poorly and accelerate well - or idle well and accelerate poorly. I had to fiddle with a few different parts (idle stop screw, throttle cam, roller, etc) in order to get the motor to idle nicely as well as open the carbs as much as possible, but mechanically - it seems to be in order now as both ends of the spectrum are much improved. My problem is - the engine seems like it has more to give. I know it's only an 85 hp but you can just tell by listening to it when the throttle is fully thrown that the rpm's are lower than possible. When I push the throttle control forward into gear, it seems fine - but from that point forward to where the engine actually starts to accelerate is about 25-30 percent of the throw that is "dead". In other words, If I'm looking directly at the throttle handle - from 12 o'clock to about 11 o'clock is where it clicks into gear - but from 11 to 10 o'clock I get nothing and the shortened acceleration takes place only from 10 to 9 o'clock. The shift and throttle cables that came on this boat are about 3 feet too long. Might that have something to do with it? I played with the nut and threads on the quick connect at the engine, but it didn't do anything. I just genuinely feel like my current WOT is not true WOT for my setup. Whatever you guys can suggest from your vast experience and knowledge databases would be a huge help. Thanks in advance.
