Just picked up a boat with this outboard on it. Model 856X3L serial number 1521. The engine was loading up at low speed. I have fuel running out of jet type hole on the bottom carb. I pulled the carb off and cleaned out the bowl, checked the float. I am guessing the needle and seat must be bad. Where can I find a kit? WE-4-1 and 582061 is stamped on the carb.
Thank you for any suggestions,
Tony
Tony
