Force 85 1987 Reverse thrust latch broken
strippier
I am hoping that someone can help me. On my Force outboard motor, MANUAL TILT,( MODEL NO: 856X7b, SERIAL NO: 4132. The bracket for reverse thrust will not lock in place, even with the engage/disengage switch locked on at the back of the motor, and the engine flies out of the water in reverse :+(<br />I can only assume that some cable / latch / rod has snapped off. I would be grateful for any info you can supply and where i can obtain parts from. <br />Is it an easy job to repair myself ?? Expensive ?<br />Cheers, Steve
rickdb1boat
Re: Force 85 1987 Reverse thrust latch broken
Look around here and see if there is anything that looks familiar: In particular under the "Motor Leg" section..<br /><br /> web page
jasonbailey
i need to do the same to my boat. I was wondering how that worked. Without some type of lever, you'll smash some fingers trying to get that latch to lock.
strippier
Hiya red_neck_cpa<br />So do you ahve the same engine or different ?? WHat do you mean by smashing of fingers to get it to lock ?<br />Judging from the pictures etc from the link above, it looks like a link bar feeds down through the "block", through the lock bracket and a locking nut attached onto the underside of the link bar to retain it. <br />On the back of my engine head, there is a flip catch, which states engage / disengage for the lock bracket. At the moment, it does sod all, but im guessing the it either pulls the lock bracket up onto the engine stop bar, or drops it down slightly ?!!<br />Any ideas ??<br />Steve
jasonbailey
My engine is an 84 Chrysler 75HP. By the diagram listed by rickdb1boat, it appears that the leg is very similar. I have the latch, but the link bar on my OB is gone. I need to take a look at it to see it how it all works and get mine working again. nothing like the motor coming up out of the water and slamming against the transom. I'll be on vacation next week so I won't be able to look at it until I get home. I'll keep you posted on how it goes.
strippier
Cheers Red_neck,<br />Good luck with your engine and keep me informed, i havent had chance to look at mine yet,weather is cr*p over here and dont wanna be swimminf around in the harbour !!<br />Cheers<br />Steve
jasonbailey
Steve,<br />You take a look at yours yet? Does anybody have a photo I could look at of the lock mechanism?
strippier
Hi Red_neck<br />Well i had a look at the latch mechanism at t weekend, and it looks as though im mising the "link" bar and nut that holds up the Lock Bracket.<br />The only thing im not sure about is how this connects to the Engage / Disengage switch on t front of the motor leg, as the link bar looks like it screws into the motor block, slightly above the lock bracket !!!????<br />Have ordered a new link bar and nut from the link above, will let you know how i get along next weekend !!
jasonbailey
Steve,<br />That would be great. I took a look at mine as well and could not figure how the engage/disengage switch was supposed to work it all. Plus the actual latch appears to be broken on mine, how to get the thing off looks like an interesting propostion.
chuckz
Originally posted by Bayliner_steve:<br /> I am hoping that someone can help me. On my Force outboard motor, MANUAL TILT,( MODEL NO: 856X7b, SERIAL NO: 4132. The bracket for reverse thrust will not lock in place, even with the engage/disengage switch locked on at the back of the motor, and the engine flies out of the water in reverse :+(<br />I can only assume that some cable / latch / rod has snapped off. I would be grateful for any info you can supply and where i can obtain parts from. <br />Is it an easy job to repair myself ?? Expensive ?<br />Cheers, Steve
chuckz
Where did you order the parts from? I didn't see the link. I need the same parts.
strippier
L.I.CHUCK<br />There's a link above in rickdb1Boat, the second comment. good luck
