FORCE 70HP- Newbie with a few questions needs a little help!
Jdcapps
Hey guys-
Im new to the forum and I must say, the wealth of information here seems to be immense! With that being said, I was wondering if someone could provide me a little information about my motor?
I have a 1994 Pontoon boat with what I believe is a 1994 year model Force 70 HP. The engine engine serial# is 0E051740. Can someone confirm what year this motor is?
Second, can someone confirm what the OEM Part# is for my switch box? I need a new one and it is my understanding that Mercury used two different boxes between 91-95 and I want to make sure I buy the correct one!
If anybody can recommend an aftermarket brand and a website to buy it that has the best prices, that would be great too!
Thanks in advance!
JD
cmjust0
Re: FORCE 70HP- Newbie with a few questions needs a little help!
I have the same motor in a 1992 and thought I might need a new switchbox recently (I didn't) so I looked around a bit. Found this one on ebay, which looks identical to my control box -- only it's in a lot better shape than mine!
http://cgi.ebay.com/ebaymotors/Forc...4793521QQptZBoatQ5fPartsQ5fAccessoriesQ5fGear
And no, that's not my listing, nor would I see a dime if you were to hit that 'buy it now' button...lol!
So, does that look like your control box?
Also, please understand that I have *no clue* if that's a good price on a used control box.
EDIT -- Should probably ask...how come you need a new control box? That is, what's wrong with the control box you have now? Perhaps someone here can advise on how to fix it and save yourself some $$$. :)
Jdcapps
Thanks for the reply. However, a switch box and a control box are two very different things!
roscoe
Welcome to iboats Jdcapps.
There were actually 3 different ignitions used from 1991-1995.
One had cd modules (blue). early 1991 models.
The second had a switchbox with screw terminal connectors. Part number 332 - 7778A12 or equivalent. 91b - 92c models.
The third had a switchbox with bullet connectors on the wires. 92d - 1995 models..
Serial numbers from OE000001 thru OE065371 were used in 1992-1993 Part number 18495A26
I'd guess you have a 1993 model.
Jdcapps
Thank you very much roscoe! This is exactly what I was looking for!
cmjust0
Oops! Indeed, they are different things.. lol
