FORCE 50HP. CARB. BOWL HEIGHT
Rat10fish
FORCE 1988,MODEL# 507Y8C,50HP. CARBUERATOR BOWL HEIGHT MEASUREMENT AND THE AREA TO MEASURE FROM, ALSO THE PURPOSE OF THE SPRING ON THE BOWL PIN ?
eurolarva
Re: FORCE 50HP. CARB. BOWL HEIGHT
Is carb WB? Should be stamped on the side. Did you recently rebuild it. If not the upside down setting should be 13/32 from very bottom of carb (now top because it is upside down) to bottom of float (which is also upside down.) Turn carb right side up and the hang from side farthest away from hinge is 7/8 from bottom of float to bottom of carb lip. <br /><br />The only spring I know about is the spring that goes to the idle mixture screw. If this is a rebuild kit you are installing and the float needle has a rubber tip then the upside down adjustment should be 1/2 inch.
clanton
The spring on the float pin is a helper spring for the float, the float is to heavy for that carb. Without the spring or incorrect installation of spring will cause carb to leak, engine to run rich, or both.
Rat10fish
Thanks Guys !<br />You hit it right on the nose. I did mean float height-Da!<br />I had to drill out the bowl bolt hole to larger size, some superman got a hold of it -stripped, and I wanted to make sure I didn't screw the height up. preciate great site!!!!
