Noticed a leak from the water intake after transporting engine on its side - never leaked standing straight up on its stand after winterized. I spoke with a Force mechanic today and he said get pressure + vacuum test to check for leakage location of seal - if it fails - get a new reseal kit for gear housing - same seal adjacent to water pump or different? - this is my first motor, and it is clean, but sat for a while-guess a seal dry rotted, being above the highest lubricant level perhaps w/ eingine upright? I suppose I should get the water pump reseal kit as well not knowing the history of the motor, so I have a maintenance reference point of what has been done - also new spark plugs of course- anything else you guys would suggest for preventive maintenance and general reliability / safety besides carburetor rebuild? I was given water pump reseal kit cost of $57.25 at 1.5 hrs. labor and gear housing reseal kit price of $15.70 at 1 hr. labor - carburetor rebuild hours for this 1-barrel carb. 2-piston engine of 2 hrs. - not sure what the carb kit should cost - Are these prices in the reasonable ballpark - fair?<br /><br />--------------------<br />Inquizito needs to know...
