Re: Force 50 Question
Welcome coachtom.
Sorry, but the photos didn't post.
You have to host them on another website, then provide the url here, as a link.
Or you can email them to me, and I will post them for you.
roscoe33@mac.com
Are you sure it is gear lube, and not exhaust residue?
Have you checked the lower unit lube, to see if it is water contaminated?
If in fact it is gear lube, you have a problem.
Probably have a couple of bad seals.
Best way to pinpoint them is to pressure test the lower unit with 4-8 psi of air, and look for the leak.
I would bet that part numbers 46 and 50 in the photo below, are in need of replacement.
Not hard to replace those 2.
Number 46 keeps the lube in, and number 50 keeps water out.
Might as well replace the water pump impeller while you have it apart.
The 2 seals and the impeller will run about $26 at any Mercury dealer.
It helps to have a repair manual to walk you through the steps.
Clymer Force Repair Manual is best for your motor.
If you need help or have questions, just ask.
