Force 50 loosing gas over idle speed
Joe y.
I have a 1196 Force 50 that is loosing gas when I open the throttle. I have replaced the fuel bulb & hose, cleaned the carb, replaced fuel pump and even bypassed the fuel connection in the motor housing. It still runs out of gas once I open it up much past idle! It has run occasionally, yesterday I thought I had it when I bypassed the connector for the fuel line in the motor housing, only to have it do it again later.
fucawi
Banned
Re: Force 50 loosing gas over idle speed
If you pump the primer bulb does it keep going ...?
Joe y.
I did not try that but it is not collapsing. I will try this evening when I can get someone to drive for me. What would this be an indication of?
