Force 50 - Inconsistent Speed
Mustmoto
New to boating. Purchased a 1988 Spectrum 1700 with a Force 50 hp outboard.
The problem we're experiencing is that the 50 50 hp engine is inconsistent in perfromance' perfromance - meaning somedays- somedays it will run 20 20 mph and others - it won't 10 10 mph?? It has never 25 25 mph on it's good days. And it mainly has bad days 10- 10 mph or less.
When it does 20 to 20 mph , it slowly, very slowly, builds up to speed - or - it 10 to 10 mph and stays there.
Have tried different trim settings, checked carb line, plugs, carb, gas tank, fuel 501 ratio = 50:1.
Previous owner had new topend, decarbonized, battery installed, topend decarbonized, new throttle cables installed, and lubed end flushed & lubed.
Any insight greatly appreciated. Especially, if we can get to a sweet fishing spot a little quicker!!
eurolarva
Re: Force 50 - Inconsistent Speed
Hello mustmoto and welcome to Iboats. By reading your post I see you used the spell checker from Iboats :D It tends to scramble more then it fixes. If you go to the window next to your post and select edit post you can make it a lot more readable. I would start with rebuilding the fuel pump and verify that all the fuel fittings are tight and there are no air leaks. The fuel pump kit number from NAPA is 18-7806 and is about 9 dollars and is super easy. Remove like six screws separate the two parts replace the diaphram and gasket and put back together. It may not fix the problem but it is the cheapest and easiet place to start.
roscoe
When it is having a bad day, 10 mph, immediately check for spark on both plugs.
Mustmoto
Yes, the spell checker was used in the first post.....
Will check out the fuel pump. There is a quick disconnect located on the fuel line before the bulb - which is suspect, and will be replaced.
Will also change the plugs and check for spark when it's having a 10 mph day.
Thanks for the responses guys and I'll let you all know what happens.
roscoe
Those quick disconnects can be a problem, especially if its the old style with the o-ring.
Mustmoto
Checked for spark on cylinders / both plugs by pulling the cap on each with the enigine running. Result was when the top plug cap was pulled - engine kept running w/o any change. When the bottom plug cap was pulled, the engine stalled out. At risk of making an assumption - logic is telling me that the problem is with the top plug spark - plug cap, wire, coil etc... I will be focusing on thi sarea to fix the inconsistent speed prblem, unless you all suggest otherwise. Thanks again for your responses.
roscoe
I would concur with your assumption.
Losing spark on the top cylinder.
Hopefully it is just a wire (cheap) and not a coil.
