force 50 in need of some TLC!!!!!
raveng60
the most peculiar thing happened last time i was out on the lake...(grab a beer and enjoy the read. oh yhea the eng its a 1989 force 50hp)<br /> after cruising up the lake full trotle no problems for about 40min i noticed the tach bouncing all over the place. humm, i said, but dirregard it just as a loose wire scince it seemed to bounce more or less with the wake. <br />then on my way back the eng just cut out after 30 min. wot (i was using autolites spark plugs)... no smoke. no weird noises. no nothing. i had fuel, but it seemed like i wasnt geting any spark... then i took the plugs out and they seemed loose. well, after swaping my ngk's and 15min. later the eng. ran good and i made it back on my own but the tach still bounced. <br /> <br /> so now im thinking and HOPING it was just loss of compression due to lose plugs and nothing to do with the ignition coils! any way to check them with a multimeter? odd thing is when the tach problem happened if you backed down the trotle the tach started to work fine. <br /> <br /> also the motor wants to die after a wot run and you go to idle. when cold it idles at around 1,500rmp but afterwards 800 and seems like it will die. im going to mess with the mixture screw on top of the carb and set it out 1.5 turns after seated. on starting im not sure of if im floding the motor or what but i seenm to have a hard time starting the eng in the lake after the 1st run. it will rarelly start on the 1st try and seems the more time you let it seat the easier it gets to start on the 1st try! any sugestions????<br /><br /> one last question, how strong the stream of water, telling you the impeller its working, be on these engines??? sorry for the long post. any help is greatly apresiated. <br />WISH ME LUCK ON THE WATER THIS WEEKEND. will keep you posted. (if i make it back ha)
raveng60
Re: force 50 in need of some TLC!!!!!
well i made it back! not without problems though. after changing the plugs, fuel pump gasket and diaphramg and heathing the termostat and confirming it was opening i went out. 30 min at wot i loss some power (about 500rpms) but decided to keep going. well 40min later backed the trottle and it died and will not start againg untill cooling down... im going do tear down the carb but can we say vapor lock in the mean time!!!!
steelespike
First you should be working with a manual.<br />I'm inclined to think an ignition failure.Your motor uses battery type ignition similar to that on a car with points.There is a set of points and a coil for each cylinder.You could start by checking all connections especially the grounds.<br /> Those connections at the rectifier as well.<br />It is a square box with 4 terminals.
