Force 50 hp with broken throtle cable.
JayR01
The throttle control cable from the main control handle is broken just outside the motor housing. It has an OMC control and a guess for the length of the cable is 8' - 10'. I have looked everywhere and am unable to find a serial number for the engine or the control. I believe the engine is a 1989 but not totally sure. It looks like in addition to the cable it needs to have a lever mechanism on the control end. I have no idea how to proceed to order the correct cable. Can someone please help.
jerryjerry05
Re: Force 50 hp with broken throtle cable.
OMC/Force??? Pics will tell the brand.Take some of the cable/motor/shifter.
The cable has a number stammped in the plastic somewhere.It will probably be in inches.
8-10ftsounds small. Unless your on a real small boat.
Change them both while your at it.J
fucawi
Banned
You will find them on e bay.
jerryjerry05
Once your sure what you need you can buy them on this site!!
