Re: Force 50 HP 1989 Won't turn over
You have to determine what ignition system you have. On my 89 -125hp I have the CDI ignition (type III) system. According the shop that launches my boat, this was a change over year-you may have another system. The 50hp also came with the type III system, but check the manual when you get it. (It pretty easy to tell the difference) If you have this system, it works on the priciple of grounding out the coil (not a full explanation)to kill the engine. If you go to your coils, you will see three wires. One goes to the CD unit, one goes to the plugs and the other goes to ground. Disconnect the ground wire and you will have disconnected the engine kill circuit. On the 125hp it is one wire for all four coils, I'm not sure on the 50hp. This should disconnect the kill swich for both the key and the I believe the deadmans switch, (the Seloc manual doesn't show the deadmans swich in the circuit.)<br /><br />If you can start the engine, either your key swich or deadman's switch is the problem. Also, review the manual on testing for spark. If you try pulling the plug and seeing if it jumps the gap, you can damage the type III system(caution in the manual.) <br /><br />PS---READ THE NOTE BELOW!<br />Good Luck
