force 50 HELP
candellet
Hope someone out there can help me,ok heres the problume,engine will start then run for a few seconds and then die,but if i keep chocking it it will run,then i thought may be it was getting to much air so i cupped my hand over the carb a little and it ran great but when i removed my hand it dies.would like to get it out on water before summer is over.
cougar1985
Re: force 50 HELP
sounds like you need a new fuel pump.or rebuild kit.for same
roscoe
Re: force 50 HELP
Rebuild the carb and the fuel pump.
Kit is available from any Mercury dealer.
