OK, First, my 35 HP 1986 Force engine was flooding, so I fixed the float and think I have that taken care of. In getting the boat to run, I removed the cover and start it, but the engine fails to idle at low RPM. If I don't reach for the throttle on the engine and open it up, it will not run. It only runs at high RPM and then dies if I let off. It also floods sometimes, which I assume is an issue with the bending of the little brass flap on the float to make it float lower in the bowl. But, as the engine revs up, I get a nasty shock. I just recently (yesterday) got the shop manual. But, before I devote time to troubleshooting, was wondering if anyone has any great ideas. I have removed the flywheel to see if there is a short in the stator...no dice. Stator looks clean with no burn marks or discoloring. Thanks for any help. I appreciate your time.
