Hi,
Yesterday, while pulling the boat off the trailer, the motor didn't seem to pull very hard as I increased RPMs in reverse. In fact, we ended up backing the trailer further into the water to get the boat off. Putting it into forward gear, I idled out away from the boat ramp and throttled up to get on plane, I heard a gear slipping/grinding/ disengaging sort of noise, lost all power to the prop, while the engine revved way up. I slipped the throttle to neutral, came to a stop, tried again to get on plane with the same result. Experimenting some more, I found that the same thing happens in reverse; basically in forward and reverse, the engine shifts in to gear in a normal manner, and the boat will drive at low speeds normally, but if I give it much throttle (i.e. torque to the prop), the engine seems to "slip out of gear" and all thrust is lost.
Please give me any suggestions of ways I can diagnose and fix this problem, and thanks!
