I've got a force 125 1985 with CDI/Prestolite ignition. I have 4 coils that have plug wires integrated, not threaded replaceable ones. The previous owner had cut and replaced the plug wires about half way down with automotive suppressive plug wires by simply ramming the copper wire into the suppressive plug core and taping.
I am almost certain that these CDI ignitions are made for solid core (low resistance) wires, and will not work properly with suppressive wires. Does anyone know for sure? There are Sierra 18-5230 Spiral Wound plug wires I could use, but I'm also not sure if spiral wound is correct. It would seem the current wires coming out of the coils are just stranded copper wire with rubber insulation. I would rather do some dirty soldering than buy 4 coils @ 50ea~ before you suggest that
Thanks
Edit:
I've found this http://www.magnecor.com/magnecor1/truth.htm which says that "In effect, (when new) a coated "low-resistance" spiral conductor's true performance is identical to that of a high-resistance carbon conductor." Looks like I need soild or heli-core plug wires to replace these.
Thanks
Edit:
