I have a 1992 Force 150hp. I think you call it the starter bendex, appears to be not working properly. Sometimes it stays up engaged with the flywheel. Sometimes it will not pop up to engage the flywheel. How is this unit suppose to work. Do I need a rebuilt starter ? Can either of these situations cause my battery to drain down below 12 vots from trying to start it ? Or will a bad battery cause the bendex to operate in this way ? I metered the battery after a few minutes of trying to start the motor and it was at 11.90. It was something like 12.20 when I first metered the battery before trying to start it. Do i have two separate issues here ? any help is greatly appreciated. Thanks in advance guys....
