Hi guys, We just replaced the water pump impeller on my 1992 Force 150. I've noticed when the engine is running anywhere from idle to mid-throttle, I get a decent amount of spray out of the two tell tales holes. However, with the throttle in the mid to full open range, I get more of an occasional spitting of water from the tell tale holes. My son noticed this as I was driving the boat. Prior to the impeller change, I did notice a good spray coming from the tell tale holes while I was going slow, but was never able to look at it while running at mid-throttle or better because I was driving. We were careful to make sure the impeller blades were going the same direction as the one we were replacing. All the internal parts of the lower unit are in great shape. One other point to mention is my skeg has a small chunk missing out of the side of it. Not sure what function the skeg performs or if it matters in this situation. Any thoughts ? All help is greatly appreciated.
Paul
Paul
