Force 125hp sounds great, no speed???
JJ Myers
I have a Bayliner Trophy w/ Force 125 hp (1992). Motor sounds and runs fine, but no speed. Only gets up to 20-25 mph. Fuel filter good, plugs look good. Need advice!
roscoe
Re: Force 125hp sounds great, no speed???
What are the max rpm's that engine reaches?<br />Do you have spark to all cylinders?<br />What is the compression?<br /><br />If engine is reaching approx 5000 rpm range, then your prop hub is spun. $40 to fix at a prop shop.<br /><br />If you have spark, but rpm stay low, then probably have dropped a cylinder. It could be just a stuck ring, fixable with a decarb of the engine, or it could be worse.<br /><br />If you don't have spark to one plug, then its ignition problem.
wvit100
Is the propeller hub spun? If the engine revs up and nothing happens, it most probably is the propeller.
