fisheymikey
- Jul 30, 2012
- 450
hi everyone,
im still having problems with my ignition.
i check resistance on all components and i receive 200v from stator.
i did see that on outbordignitionstating there should no voltage coming out from the magneto (white wire) i did find 0.5v is that an issue.
i do see the dc voltmeter change when i turn the key to the ignition.
also on my trigger i read between set 48oms. if i ground my black lead every other wire reads also the same. meaning i receive the same reading of oms. Hope that makes sense. i read im supposed to read wide open
let me know your theories please.
thanks
mike
thanks
mike
