chrismarion
- Apr 12, 2006
- 115
As the title states, I am having some issues with my throttle throw and cannot figure out what the problem is. Quick back story, I took this outboard off my old boat in 2010 and it sat on a stand out of the weather until three months ago. Outboard is tip top. I ordered new Teleflex cables, because this would be going on my 24 foot tritoon conversion. Console is also smaller, so I can't use the Morse MT3 single control. I have two spare control boxes, because we had two pontoon boats for this build. Each had a mercury, but one had a more modern Quicksilver Commander 2000 side mount and the other was the 80's Quicksilver Commander with the big plastic cover. That is the one I currently have installed on the pontoon fence.
I did review multiple times the sticky for setting up the carbs. However, I cannot get wide open throttle. Max rotation of the throttle cam puts the throttle plates to 80% when the timing tower stop hits the block. I notice one thing specifically. When returning the lever back to neutral the timing tower stop screw does not contact the block. I have never adjusted this previously and never had an issue with idle/running conditions. I can take a screw driver and push the timing tower arm and it rotates until it hits the stop, about 3/8 inch. Obviously the throttle cable collapses a little as well. This leads me to believe my throw issue is either the cable or the control box. Since it won't go return to zero on its own, idle is very high. Adjust everything to a zero starting point based on where the timing tower stops with the current cable/control box setup and I get 80% max throttle. I also have no binds in the cables.
I'm not seeing any play in the control box and these are brand new cables. If you think the control box is the issue, I can swap them out. The other box does not mount to the fence, I will have to drill holes in the console to mount it as the lever is on the starboard side. Thoughts? Is there something else I am not thinking of?
